September 25, 2018 at 8:29 pm
jjaafar68
SubscriberDear all,
I'm using Ansys Apdl v16 to model simple concrete beam under static load by using Solid65 element.
after plot load-displacement curve , the curve stopped at the maximum load, unlike experimental there are no negative slope in the curve.
my question is,
is there any way to plot full load-displacement curve with the negative slope ? like the graph.
September 25, 2018 at 8:47 pm
mekafime
SubscriberHi,
I usually change the sign in excel
September 25, 2018 at 10:41 pm
Sandeep Medikonda
Ansys EmployeeHi, Isn't that post-buckling behavior?
Did your model run to completion? I suspect it hasn't?
Buckling is a numerical stability and your tangent stiffness matrix is going to zero.
You can overcome buckling by adding some stabilization energy to your model.
Sandeep
September 26, 2018 at 12:01 am
peteroznewman
SubscriberWhat was the load in your model: a force or a displacement? A force load cannot solve past the maximum force, that is why it is required to have a displacement load on your structure and extract the reaction force. A displacement load can track a reaction force reaching a maximum and then plot the negative slope.
Peter
September 7, 2020 at 9:42 am
OguzhanA
SubscriberBut if we have to apply environmental pressure (like external pressure) to a cylinder, we can't add displacement there, right?n
- The topic ‘negative load-displacement curve’ is closed to new replies.
6450
