March 26, 2019 at 10:06 amsimakz2010 Subscriberhi all
 I am going to do a project in ansys maxwel, actually i need to add a magnet and i know i have to do it with add material. my magnet is NdFeB . i give the material from net, actually i can not valid them because they are different in value. I need to calculate Mu(permeability ) and I nedd exact value for Hc and Br for this magnet. is there anybody here knew about that or use this magnet before? is it linear or none linear in practice? i will appreaciate any kind of response
May 3, 2019 at 4:41 pmMark Christini Ansys EmployeePlease reference Maxwell online help topic: Nonlinear vs. Linear Permanent Magnets.  You need to decide which is appropriate for your specific material and application.
 For linear permanent magnets, you must provide as input 2 of 4 quantities: Br, Hc, mu, Mp. Please reference Maxwell online help topic: Calculating the Properties for a Permanent Magnet
 For nonlinear permanent magnets, please reference Maxwell online help topic: Calculating the Properties for a Non-Linear Permanent Magnet
June 28, 2019 at 10:08 amsimakz2010 SubscriberThanks a lot Christi and sorry for late answer because I had forgotten my password .
 I find way to simulate it to some extend. But I want to impose Magnetic earth field as an external fixed field to my project. Do you have any idea on that?
June 28, 2019 at 11:36 amMark Christini Ansys EmployeePlease reference Maxwell online help topic:Â Assigning a Magnetic H Field for a Magnetostatic Solver
 Use this for 4 sides and then even symmetry on remaining top and bottom of region background.
- The topic ‘needing properties of NdFeB for simulation’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
                        4167
                        1487
                        1363
                        1194
 You are navigating away from the AIS Discovery experience
