Need to learn about fluent batch options
    • rumth
      Q1. nWhen I want to submit a job in the cluster, I need to set the batch options. I have found three options in fluent (overwrite files? yes; hide questions? no; exit on error? yes). So I expect to set the batch option as follows:n/file/set-batch-options yes no yesnBut I have found some journal files where batch files have been set as follows:n/file/set-batch-options no yes yes nonWhich one is right? If second one is right, how 'no yes yes no' have been set?.Q2. Which command line is right among the following:n file set-batch no yes yes non/file/set-batch-options no yes yes nonn n n
    • Keyur Kanade
      The questions for this command are nDo you want to confirm file overwrite nDo you want to exit on error?nDo you want to hide questions?Please user appropriate options depending on your case. The questions are self explanatory. nPlease check description of the command at nnRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
    • rumth
      Thanks for your reply.nIn the following link, I have found four options instead of three (that's what I asked in my Q1). What does the extra one mean?.nhttps://docs.rescale.com/articles/ansys-fluent-batch-tutorials/#ansys-fluent-in-batch-moden
    • DrAmine
      Hi you need to check the options in the documentation to know what is behind each of one. Please always check the official Ansys documentation before raising any kind of questions and referring to other website articles.nnThere are only three options. The forth placeholder will appear if you decide to hide questions asking you to redisplay questions.nnnIn
  • The topic ‘Need to learn about fluent batch options’ is closed to new replies.
