June 24, 2023 at 5:08 am
Krishna Kumar
SubscriberI am using Ansys Maxwell for motor design, I have already applied sufficient torque but my Speed continuously increases and the torque is oscillating between positive and negative cycle
June 27, 2023 at 12:09 pm
HDLI
Ansys EmployeeHello Krishna,
Could you provide more information on it? Which motor type are you simulating?
Do you use RMxprt to generate Maxwell FEA model? Thanks.
HDLI
June 27, 2023 at 12:24 pm
Krishna Kumar
SubscriberI am using Ansys Maxwell directly to configure PMSM motor.
June 28, 2023 at 3:52 pm
HDLI
Ansys EmployeeCould you use RMxprt to create similar model to compare winding sequence and pattern, and us external circuit? The key is the excitation should follow rotor position to provide power because PM motor is synchronous machine. BLDC RMxprt model would generate Maxwell model with external circuit, that can perform this drive. Please check them.
HDLI
- The topic ‘need support in Ansys Maxwell’ is closed to new replies.
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
4597
1495
1386
1209
