December 19, 2019 at 2:15 pm
December 19, 2019 at 3:07 pm
Forum ModeratorHow long has it been stuck for? What load do you have on the cpu?
December 19, 2019 at 5:01 pm
shraypandey18
Subscribermy pc is 16gb, windows 64 bit i5 6 cores 2.8ghz its an excellent pc and i don't why its taking so much time
December 20, 2019 at 9:29 am
Forum ModeratorPlenty of disc space? How long is "long"?Â
December 20, 2019 at 12:24 pm
peteroznewman
Subscriber I recognize this model from the Cornell course. Did your computer solve other models before this?
December 20, 2019 at 1:18 pm
shraypandey18
Subscriberyeah im my college i had solved 3d models of beam under udl
shraypandey18
Subscriberi kept it on for like 30 mins then i closed itÂ
December 23, 2019 at 10:31 am
Forum ModeratorCheck the cpu/RAM loading incase something else is the root cause. Also confirm the model is correctly set up: if you're missing a fixed constraint or similar the solver may be trying to work out where the whole model is going.....Â
December 23, 2019 at 11:43 am
peteroznewman
SubscriberTry rewatching the video, then start with a new file and build the model over again. If you attach an archive .wbpz file, I will look at it to see what you did wrong.
December 23, 2019 at 12:13 pm
shraypandey18
Subscriberthanks a lot guys but i solved a few things in my pc and ansys started to work smoothly
- The topic ‘need help’ is closed to new replies.
6084
