November 25, 2024 at 6:40 pm
jkl6588
SubscriberÂ
not entirely sure what happened. was trying to follow this tutorial (Thermo-Structural Analysis of a Brake Using Ansys Mechanical - Lesson 3, Part 1) as closely as possible (barring the rotor acceleration curve) and the software simply would not run...
any help/ advice?
November 26, 2024 at 3:14 am
harrygross616
SubscriberIt sounds like the issue could be with the setup or compatibility of your inputs. Double-check the boundary conditions, material properties, and meshing to ensure everything aligns with the tutorial. If the rotor acceleration curve was skipped or modified, it might be affecting the simulation.Â
November 26, 2024 at 8:29 pm
jkl6588
SubscriberThanks for replying @Harrygross616.
I've gotten to the point where I've smoothed out what are most of the error messages, but am left with just these errors: *** WARNING ***             CP =    2.380  TIME= 02:42:26 Material property ALPX of material 3 is evaluated at a temperature of Â 22, which is below the supplied temperature range. Temperature range Â checking terminates.                          Â *** WARNING ***             CP =    7.319  TIME= 02:42:27 The Memory_Option on the DSPOPTION command for the distributed sparse Â solver should be either DEFAULT, INCORE, OUTOFOCORE or FORCE. This  Â field is reset to DEFAULT.                       Â *** WARNING ***             CP =    9.234  TIME= 02:42:28 Element shape checking is currently inactive. Issue SHPP,ON or    Â SHPP,WARN to reactivate, if desired.                  Â *** WARNING ***             CP =   29.018  TIME= 02:42:36 Contact element 360581 is missing DOF TEMP (and possibly others) of  Â underlying base element 48108. Similar mismatches may exist      Â elsewhere, but checking for this is discontinued.           Â *** WARNING ***             CP =   67.411  TIME= 02:42:56 For element 220842 the element connectivity is 0 and 286092. The node Â which is identified as a 0 will be a grounded node.          Â *** WARNING ***             CP =   95.564  TIME= 02:43:04 Coefficient ratio exceeds 1.0e8 - Check results.            Â *** WARNING ***             CP =   120.530  TIME= 02:43:25 Pivoting has been activated for the Sparse Matrix Solver . The memory Â required may greatly exceed the predicted amount. In that event, use Â the DSPOPTION command to change the memory mode and/or memory size   Â used by the Sparse Matrix Solver.                   Â
I am not entirely sure just how to find these specific elements that seem to be grounded or don't have their thermal DOF turned on (although both of my frictional contacts have them as per the tutorial).
The other very worrying thing is the ground node, definitely should not be fixed at all anywhere...Âmy mesh solution asdp already has dspoption,,high -- so its probably the two elements causing the matrix to be very sparse and fail.
6309
