TAGGED: ansys-cfd, ansys-cfx, automation, automation-code, batch-script, bladegen, blademodeler, meshing, turbogrid, turbomachinery, vista
October 6, 2025 at 2:45 pm
prajwaln.ae22
Subscriberhi , i am working on a project where there is a requirement to obtain mesh xyz data points of 2000 blades of a compressor,Â
problem is i have looped or automated the the blade generation in blade editor but facing problems in meshing these parametrized blades in turbogrid and store thier mesh data ,,,tried running scripts but always faced some unexpected error, so could some body help me in this by ur suggestion or by sharing a reference script for the Automated meshing processÂ
with regards,Â
Prajwal NÂ -
October 7, 2025 at 7:54 am
Petros
Ansys EmployeeHi, can you provide more information regarding your workflow? How are you doing the automation? What parameters are you changing?
If you are using Workbench, then you can set the required variable as a parameter and populate with the required values, then update the full project.
You can also have a look at PyTurboGrid if you are in standalone mode.
October 7, 2025 at 12:35 pm
prajwaln.ae22
Subscriberthanks for your response petros
so i am changing the thickness in the blade editor and parametrised themÂ
i have created more than 50 blades through that , now i need thier mesh node coordinates in a csv file of all 50 blades , i tried connecting it to turbo grid and run the project but it was not happeningÂ
so it would be great if u could help me in this to obtain the mesh csv file of all 50 blades thorugh script or like thatÂ
below is attached screen shots of the project
October 7, 2025 at 1:41 pm
October 7, 2025 at 6:22 pm
prajwaln.ae22
SubscriberGreat thanks for that
But can i automate this process somehow where i wont need to do this this manually for every balde
October 8, 2025 at 7:50 am
Petros
Ansys EmployeeYou can use a Fluent journal for that.
October 17, 2025 at 4:15 am
prajwaln.ae22
Subscriber i tried Journal to Automate the meshing process, it workedÂ
Thankyou PetrosÂ
5824
