3D Design
3D Design
Need assistance installing Discovery Subscription
    • Daniel Dart
      All machines are Windows 11.
      Walter's computer gives an error disco_level2
      Requested version (v2021.1108) of Discovery - Level 2 (feature disco_level2) is not supported by current Ansys subscription licenses.
    • subashni.satish
      Hello Dan Dart
      Can you please share the screenshot of the error you see?
      Also, can you please share the below log file at the  below location
      discovery-installation folder/Ansys Inc
      Install.log
      Install_licconfig.log
      Install.err (if it exists)
    • Daniel Dart
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      This is the content of the error:  I didn't get the snapshot saved.  Requested version (v2021.1108) of Discovery - Level 2 (feature disco_level2) is not supported by current Ansys subscription licenses.  I have requested the files.  I also have the compatibility and hosts file attached.
    • Daniel Dart
      Also please confirm this means WIndows 11 is not compatible: (Since it says Windows 10 , lists versions and adds "or later", I assume that means Windows 10 versions only?)
      Operating System Requirements
      • Microsoft® Windows 10 version 21H1, 20H2, 1909, or later (Professional, Enterprise and Education)
      • Supported Releases: Semi-Annual Channel and Long Term Service Channel (Windows 10 Only)
    • Daniel Dart
      Subashni, I have attached the requested files.  Let us know the next step please.
    • Daniel Dart
      Subashni, Does ANSYS Discovery work the same way as ANSYS regarding geometry interface license?  Ie you configure as reader instead of plug-in if you don't have the license and Discovery will import an IPT file directly but it won't be associative?
      • Devendra Badgujar
        Dan Dart
        I will check and update you soon on this.
    • Devendra Badgujar
      Hello Dan Dart
      Please can you share the %TEMP%.Ansys directory for the user ?
      Also please share the customer email address and customer number to check the license details for this license issue.
      Regards.
    • subashni.satish
      Hello Dan Dart
      Is this customer's issue resolved?
      Can you please try disabling Intel graphics from BIOS?
    • mrizuwan
      What is mean by "required discovery level 1"?
Viewing 8 reply threads
  • The topic ‘Need assistance installing Discovery Subscription’ is closed to new replies.
