July 10, 2024 at 6:58 pm
puh69
SubscriberHello,
I notice a massive spike in my pressure derivatives close to the wall in my airfoil simulation and am looking for some direction to remove them. I believe this is unphysical and for the work I want to do from here, I need this to be accurate. My goal is to write a UDS where the pressure gradient is a source term and it'll have many issues near the wall if I employ the UDS with the current state of the flow solution.
Thanks!
July 11, 2024 at 8:49 am
Forum ModeratorCan you show contours in that region, node values off. Is the above spike the cell or facet value?
July 11, 2024 at 3:36 pm
puh69
SubscriberHi Rob,Â
This is not a single value problem but occurs at many cells close to the wall and I've observed these artifiical gradients on various simulations. Attached is the contour in the region along with a closer look at the dp/dx behavior in those final cells. I've attached plora od both cell and nodal values. Please note values are slightly different as I continue to work on this issue to find a solution but the problem remains regardless of the numerical approach.
July 11, 2024 at 4:21 pm
Forum ModeratorAre you running single or double precision? How thick are those cells?
July 11, 2024 at 4:46 pm
puh69
SubscriberDP always.
Using TMR 0012 1793x513 grid which states minimum spacing at the wall of y=4 x 10-7
July 12, 2024 at 9:27 am
Forum ModeratorLook very carefully at the near wall values. At that scale you may find the cell height (dx) to be so small that the gradient is d(big number)/d(near enough zero) to give some noise. The solver gradients will be fine, it's the reporting I'd be checking.Â
July 12, 2024 at 1:13 pm
puh69
SubscriberRob, I want to use the dp/dx and dp/dy terms as source terms in a UDS and when I do so these errors are significantly magnified. I understand that the margin of error increases with the reduction in the dx factor, but its also present in the dp/dy component too.
Cheers,
Pierce
July 12, 2024 at 2:13 pm
Forum ModeratorYou need to zoom in so we can see what's happening.Â
July 12, 2024 at 3:14 pm
July 15, 2024 at 9:05 am
Forum ModeratorAnd now the pressure & contours?Â
July 18, 2024 at 7:51 pm
puh69
SubscriberHi Rob,Â
These look fine, but the devil is in the detail. If I put the dp/dx term as a source term of a UDS the value in the BL will blow up!
July 19, 2024 at 10:13 am
Forum ModeratorAs I can't see the contours it's very hard to comment. Please plot with node values off and post here.Â
July 19, 2024 at 1:21 pm
July 19, 2024 at 3:01 pm
Forum ModeratorOdd, how many cells are there in the unstable region? You may need to alter the colour map scale to improve clarity.Â
- The topic ‘Near Wall Pressure Gradients’ is closed to new replies.
5849
