January 7, 2021 at 8:37 pm
Rajdeep_11
SubscriberThis is my first time using ANSYS so this is a basic question. I am using a porous cubic material and I want to select the faces on the top surface. Since I am using an STL file my entire geometry is divided into triangulated faces. how can I select all the triangular faces on the top surface without selecting any of those in the pores? When I use box select it always selected the faces in the depressed pores too. I want to apply parameters to this selected face. Can anyone please help me?
January 7, 2021 at 10:30 pmpeteroznewman
SubscribernOpen the Geometry in SpaceClaim. Create a Plane on the top of the block.nUse the Move tool to move the Plane 0.1 mm in the -Y direction.nUse the Split Body tool to split the solid body with the Plane and delete the sliver solid.nNow you have one big face on the top of the block.nYou could use the Pull tool to pull that face 0.1 mm in the +Y direction if you want to restore the original thickness.nJanuary 7, 2021 at 10:37 pmRajdeep_11
SubscriberI actually did that but I have already generated the volume meshes in 3-matic. So when I tried to do some calculations there were some errors. Should I skip the volume mesh generation part there and take it to space claim as it is?nJanuary 8, 2021 at 4:01 ampeteroznewman
SubscribernI don't use 3-matic so I don't know what it does well.nOne thing you can do in SpaceClaim before you mesh is to convert the STL back to a Facet Body and try to use the Shrinkwrap tool on the facet body to put fewer smooth faces over the facets.nJanuary 9, 2021 at 2:29 pmRajdeep_11
SubscriberThank you! The shrinkwrap tool solved the issue.nViewing 4 reply threads- The topic ‘Named selection of a plane of triangulated STL file for applying parameters.’ is closed to new replies.
5154
1836
1387
1248
