July 27, 2021 at 2:25 pm
lei2019
SubscriberHi,
This is LES simulation of coal combustion, by species model, Discrete phase model, DO radiation; the particle number reaches up to 50 million;
using 2021R1, automatic Metis partitioning, single precision;
using two udf file to define coal properties wsg for radiation and define ash volume after coal burnout.
I use 120 processors to run this case by issuing command
/project/research/ansys/reserve_fluent.sh 120Â
/project/research/ansys21/fluent21 3d -t120 -cnf=/home/research/username/fluenthosts.88888 -pib.ofed -gui_machine=chernobyl.engr.wustl.eduÂ
I issue these commands in VNC session using one processor. the system is
July 27, 2021 at 2:47 pmDrAmine
Ansys EmployeeFirst of all running this kind of runs with single precision is a bad idea.
Second: you should keep track of memory usage of the case every couple of iterations using (proc-stats) and watch for excessive memory loading over time.
Third: Rough estimation for your case: you require a minimum of 75 GB RAM and even more for single precision: do all your 120 CPUS together offer that?
July 27, 2021 at 2:59 pmlei2019
Subscriberthe mesh is 3 million, and if using double precision, reading data file will encounter issues in ANSYS; H5 temporarily solve this issue. now the data file is about 12GB; if using DP, then it will double the size. and the particle parcel reaches about 50 million, which Fluent has difficulty handling.
The momery has been tracked by cluster administrator every tenth of a second; and no abnormal situation till now.
July 27, 2021 at 3:00 pmJuly 27, 2021 at 3:14 pmDrAmine
Ansys EmployeeSo CPU usage is high from the beginning on the Gui Machine?
July 27, 2021 at 3:20 pmRob
Forum ModeratorCortex problems can be linked to graphics. Are you displaying anything other than residuals and a few monitors.
Re double precision, without it the data may not be as accurate as you'd like. 50 million particles is also fairly high.
July 27, 2021 at 3:43 pmJuly 27, 2021 at 3:52 pmRob
Forum ModeratorPictures of what?
July 27, 2021 at 3:53 pmlei2019
SubscriberThe picture shows the GUI interface resource, 1 node, 1 core.
July 27, 2021 at 4:01 pmRob
Forum ModeratorWhat do you use execute commands to save pictures of?
July 27, 2021 at 4:02 pmDrAmine
Ansys EmployeeAre you able to see similar CPU load if running in batch without graphics?
July 27, 2021 at 4:14 pmJuly 27, 2021 at 4:45 pmJuly 28, 2021 at 2:08 amlei2019
Subscriberbased on cluster administrator, the head node overloaded with too much work; this is the reason why the VNC gui is slow, not because of Fluent.
July 28, 2021 at 5:28 amDrAmine
Ansys EmployeeThanks for the feedback. But in general Rob and I presented the steps which we usually start doing / asking when things like that appears! :)
So it will be good if you run one time with -gu -driver null flag and check the CPU consumption on the Cortex.
July 29, 2021 at 4:47 pmlei2019
SubscriberSince now I can't stop the simulation, I will try it later. Thank you.
Viewing 15 reply threads- The topic ‘mysterious high CPU usage in HPC cluster’ is closed to new replies.
5709
