September 1, 2024 at 3:20 pm
Barbaros DeÄŸerli
SubscriberHi, im having a problem with the solution. the error as below, what might be the problem?
Resources file 'D:\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ANSYS Inc\ANSYSÂ
 Student\v242\CommonFiles\Language\/fx0.msb' not found.                Â
 CADOE_LIBDIR242 = D:\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ANSYS        Â
 Inc\ANSYS Student\v242\CommonFiles\Language\                           -
September 1, 2024 at 7:10 pm
peteroznewman
SubscriberIs this the first time you solved a model after installation of this version or have other prior models solved successfully on this version?
September 2, 2024 at 5:23 am
Nanda
Ansys EmployeeÂ
Hello Barbaros,
To add to Peter’s comments, can you also check if the fileÂfx0.msbexists in the directoryÂD:\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ANSYS Inc\ANSYS Student\v242\CommonFiles\Language\. If it is missing, that is likely the cause of the error.
If the file is missing, you can try creating a new directory as suggested in the below forum thread, and then copy the file from another installation of Ansys or a backup if available. This approach has reportedly resolved similar issues for other users.Please try this and let us know if the issue persists:
Got some errors on running Ansys MechanicalRegards,
Nanda.
If you are not able to open Ansys help links, refer to this forum discussion:Â How to access the ANSYS Online Help
Also, we launched a public help documentation website: Ansys Help
For more exciting courses and certifications, hit this link: Ansys Innovation Courses | Ansys Innovation Space
