June 7, 2019 at 6:39 am
dhirajlote
SubscriberHello Sir,
I am using CFX 19.2 with MUSIG model (7 size groups). I have run the simulation and got the converged solution. Sir, I would like to ask how to plot the bubble size distribution as a function of bubble diameter?Â
June 7, 2019 at 11:00 am
Amine Ben Hadj Ali
Ansys EmployeeXY Chart might be useful here:Â Size fraction or Number density vs diameter / size of the bin or you can do it in third party program.
June 7, 2019 at 11:13 am
dhirajlote
SubscriberThank you for the reply.
"Number density/diameter/size of the bin" none of these options are available in the CFX.
Regarding MUSIG model the only available options are "Polydispersed Fluid 1.Group 1.Size Fraction"
I dont know how to get options like, bubble diameter, number density etc.
June 7, 2019 at 12:19 pm
Amine Ben Hadj Ali
Ansys EmployeeBut you know the size of the bin as you have set up the case right?. All other quantities might be derived.
July 1, 2020 at 9:33 pm
Richard_Marx
SubscriberHi Amine,Â
For the polydispersed phase, what exactly does "size fraction mean" ? Is that just the fraction of our polydispersed phase divided by total polydispersed phase in that area? So for the polydispersed phases our size fractions should add to 1? Similar to a volume fraction?Â
I think I am after the same thing as the student above, and would like to understand my polydispersed phase's diameters and locations. You're saying the best way to do this is I will need to create an expression to calculate my mean particle diameter?
I found these slides (apparently from Ansys)Â http://ptsanmiguelense.com/wsMescal/server/manualesSSC/CFX160_Multiphase_Workshop_08_MUSIG_and_Non_Drag_Forces.pdf
that seem to use mean particle diameter for the polydispersed air? Did they create this variable or is there now a way for Ansys to generate that number?
Thanks!Â
July 2, 2020 at 4:40 am
Amine Ben Hadj Ali
Ansys Employeevolune fraction of bin/volume fraction of phase. -
July 2, 2020 at 4:41 am
Amine Ben Hadj Ali
Ansys Employeemean particle diameter is available you fo not need to create anything
- The topic ‘MUSIG model’ is closed to new replies.
4607
1510
1386
1209
