Multipoint path with Python
    • thermalsr71
      Hello, I'd like to create a path made of several points so that it follows a precise shape and direction instead of it being a straight line with only two points defining it (start and end coordinates). I know it can be done with APDL commands but I'd like to do it through the Mechanical Scripting itnerface.
      Does anyone know how to do that?
    • ErKo
      Hi
      Whataver you do manually in Mechanical (create paths say using points or edges, etc), we can do with scritping also. So scripting basically automates anything done manually & repeatedly in the Mech. UI.
      So if you can create the paths manually using the edge,two points or x axis intersect options (these are the only ones available in mechanical), we can also use scripting to do the same.
      All the best
      Erik
  • The topic ‘Multipoint path with Python’ is closed to new replies.
