Multiple values on the interface node
    • Shivam Verma
      I am doing a CFD analysis on Fluent in which a hot plate is dipped in a fluid and the plate loses heat. That heat is responsible for the driving of natural convection in the water. The solution is converging with a residual of E-6 or less. The data shows that on the interface nodes, there are multiple values of the velocity and temperature. Ideally, there cannot be various values. Please help me with this.
    • C N
      Hello Shivam,
      Can you send the screenshot of the interface boundary condition?
      Please check your boundary conditions at interface.
      Thanks,
    • Shivam Verma
      Hi C N,
      Thank you for responding. It's a couple analysis using Transient heat transfer and transient Fluent Modules. Here are the boundary conditions from the CFD module:
  • The topic ‘Multiple values on the interface node’ is closed to new replies.
