Ansys Products
Ansys Products
Multiple products using ansys license server(s)
    • kindires
      We have two software for which we need to configure the license server(s). They are granta and lumerical.
      Could we run two ansys license servers on the same machine serving licenses for the two software via two different ports for this purpose?
      or
      Is it possible to have one license server serve licenses for multiple ansys products?
      Which is the preferred way?
    • ANSYS_MMadore
      If the licenses have the same hostname and hostid they can be combined and installed through a single Ansys License Manager setup. You cannot run 2 instances of the license manager on a single machine. If combining the licenses, you need to only have one SERVER and one VENDOR line in the file.
      Example:
      SERVER licserve 105156ac6b01 1055
      VENDOR ansyslmd
      USE_SERVER
      #first license
      # Products licensed in this file:
      # LIST OF PRODUCTS
      INCREMENTS of 1st license file
      #second license
      # LIST OF PRODUCTS
      INCREMENTS of 2nd license file
    • kindires
      Thanks. It is very helpful. We work via command line on linux. Is there an ansys utility to combine license files or can we just do it manually?
    • ANSYS_MMadore
      You need to do it manually, with any text editor.
  • The topic ‘Multiple products using ansys license server(s)’ is closed to new replies.
