April 17, 2024 at 8:10 am
Tonmoy
SubscriberHello everyone!
I am trying to understand the response of a structure on a soil domain by SSI analysis and my model needs to utilize the DRM technique. LS-Dyna just warns by printing some messages similar to the one provided below (from d3hsp):
*** Warning 50134 (MPP+134)
Tracked node also belongs to reference segments
connectivity. This should not cause numerical problems.
tied interface # = 1
tracked node # = 1
segment # = 179
segment nodes:
22 463 442 1
Summary of warning messages for interface # = 1
number of warning messages = 4418In that case the solver reports the following errors in the d3hsp01:
At line 253932730:
*** Error 30264 (INI+264)
SSI interface ID: 1 not found in restart file
At line 253932733:
*** Error 30271 (INI+271)
# of nodes 4418 in SSI contact interface id 1
do not match stored # of nodes: 890217136I want to understand how to troubleshoot these errors and whether they are related to the manner in which the *INTERFACE_SSI was defined. I know about the implementation and theory of effective seismic input that LS-Dyna employs in the background according to Bielak's 1984 article.
Thanks in advance for your valuable insights and time.
- Tonmoy.
April 17, 2024 at 11:25 pm
Ushnish Basu
Ansys EmployeeThe surface for INTERFACE_SSI_STATIC should match that of INTERFACE_SSI. If you use OFFSET in one, use it in the other too.
Also, there is no need to specify a single-element DRM layer - the effective seismic input in LS-DYNA follows Bielak's earlier papers, not the later ones. The only requirement is that the PML should be at least two elements away from the INTERFACE_SSI
Possibly, even in the dynamic case, the meshes on either side are not separated (you should see duplicate nodes on the interface when you highlight it in LSPP)
April 18, 2024 at 3:38 pm
Tonmoy
SubscriberThank you very much, Dr. Basu, for the insights. Now I can understand what we were doing wrong. I’ll let you know if there are any more questions.
Have a good rest of the day!
- Tonmoy.
April 21, 2024 at 7:38 pm
Tonmoy
SubscriberDr. Basu,
I have tried to initialize the gravity on the structure and not the soil, but it fails. So, I want to start this analysis from scratch. Thank you again for your time and help.
- Tonmoy.
April 21, 2024 at 11:12 pm
Ushnish Basu
Ansys EmployeeThe PML boundary has to be placed at least two elements away from the INTERFACE_SSI, where the LOAD_SEISMIC is applied. It's up to you to decide where to put the INTERFACE_SSI - if the foundation pad is not sliding on the soil, you can even place it at the pad-soil interface. Else, you can define the INTERFACE_SSI at a small distance from the pad, so that it encloses any non-linearity near the pad.
April 22, 2024 at 3:31 am
Tonmoy
SubscriberDr. Basu,
Thank you for taking the time to respond to my query. I greatly appreciate your assistance.
Now, the problem is that if I do not include the soil part for initialization in the static phase, the restart transient analysis terminates issuing a warning that the nodes of the soil domain interface have 0 forces.
I want to understand if there is any way to circumvent this issue.
- Tonmoy.
April 22, 2024 at 5:03 am
Ushnish Basu
Ansys EmployeeTonmoy,
Please specify only one INTERFACE_SSI_STATIC, and only one INTERFACE_SSI - it is not meaningful to specify more for this problem.
April 22, 2024 at 7:20 am
Tonmoy
SubscriberThanks a lot Dr. Basu for all your help. That'll solve the issue.
- The topic ‘Multiple INTERFACE_SSI layer for implementing DRM’ is closed to new replies.
6510
