TAGGED: -2d-materials-and-metals, #multiphase_models, fluent
May 6, 2024 at 5:27 pm
Nawaf Rasheed
SubscriberGreetings
I'm multiphase model with different zone condition:
1- SolidÂ
2- Phase 1 (water liquid on fluid wick)
3- Mixture (on vapor)
Everytime when I change phase condition on one Fluid Zone, the other Fluid Zone phase changed aotumatically to the same type
Why? and how can I have different phase condition on the same model?
May 7, 2024 at 10:28 am
Forum ModeratorI suspect you've misunderstood the set up. A solid zone is "solid" so isn't flowing, only conduction is solved. In the multiphase model(s) the fluid zone will have mixture, phase-1, phase-2..... phase-n options in the zone. We typically don't need to alter anything in the fluid cell zone panel. You will need to initialise & patch (plus boundary conditions) to set the phase values. Have a look at the various tutorials in Help & Learning.Â
May 7, 2024 at 4:58 pm
Nawaf Rasheed
SubscriberThank you Rob for your response
I did watch totirals, so the only way the setup different zones is by initialization + patch?
I'm going to explain my situation more.
After I initialize and patch the model as shown in a picture, but when I solve the problem phases get mixed with each other. The phase change sould be happening in mixture zone only (small layer between wick and vapor region).
How can I achieve the previous conditionÂ
Again Thank you Rob for continuous supportÂ
May 8, 2024 at 9:22 am
Forum ModeratorInitial conditions are just that, a starting point. In your model, if you have porous media as part of the heat pipe I might initialise as all gas/liquid and then patch the porous/open regions as liquid/gas respectively depending the total mass of material in the device. Note, you will need a compressible gas and these models are NOT trivial - I'd be working with another colleague for this sort of problem as there are several aspects that may require a better theoretical knowledge of the code. That level of assistance is well beyond what we can cover on the Forum.Â
- The topic ‘Multiphase with different phase zone condition’ is closed to new replies.
5934
1306
