August 31, 2023 at 4:34 pm
Kirei
SubscriberDear all,
I Intend to simulate slurry flow that consists of air, water, and ore, so it will be three phase simulation in Ansys CFX. The phase modeling that I did was:
- Water: Continuous fluid
- Air: Continuous fluid
- Ore: dispersed solid
I used in-homogeneous multiphase model (with standard free surface model) and homogeneous turbulence model. I want to simulate a steady-state simulations of the slurry fills a box with one inlet and several outlets (at first the box is filled with air only).
I faced a problem when I modeled the ore particle-particle interaction with kinetic theory. The problem that I faced was the simulation was not converging. It showed residuals that do not converge and go up and down very unstable. However, when I turn of the kinetic theory model, the result can be obtained and more stable (even though it did not converged to the residual target, but still stable than when I turn on the kinetic theory model).
I already read several journal regarding multiphase flow that involves solid, activating kinetic theory model is best for modeling particle-particle interactions.
Does anyone have suggestions to solve this problem?
Thank you very much.
September 5, 2023 at 9:54 am
V.P
Ansys EmployeeHi Kirei,
The kinetic Theory model is suited for transient simulations. Have a look at this, these are modelling guides for solid particle collision models.
7.9.3. Kinetic Theory Models
Thanks
September 5, 2023 at 9:57 am
V.P
Ansys EmployeeThe fact that your simulation becomes unstable when you enable the kinetic theory model suggests that there may be issues with the model setup.
Check the mesh quality and make sure the time step size. Try reducing the time step size and see if it improves convergence.
September 8, 2023 at 2:29 am
Kirei
SubscriberDear CFD_Friend,
I already checked the model setup and I believe the setup is correct because I made a simulation comparison from a reference about water-sand modeling and it worked. So from your suggestion better to use transient simulation to simulate using the kinetic theory model?
January 3, 2024 at 6:56 pm
Thusira Pramod
SubscriberDear all,
I'm simulating a slurry flow which consists of water( continuous fluid) & particles (dispersed fluid). But the problem is that once I simulate this pipe flow and compare the pressure results with my slurry flow and normal water flow, the results are the same. But the volume fraction at the outlet in slurry flow is getting kind of acceptable values, but still, that is also not correct. Velocity results are comparatively ok. Need help to solve this.
Thank you.
January 4, 2024 at 9:31 am
Forum ModeratorAny staff comments will be made in /forum/forums/topic/multiphase-flow-2-phase-water-particle/Â however I'll not lock this thread to give Kirei the opportunity to respond should they desire.Â
- The topic ‘Multiphase Flow: Slurry Flow (Three Phase Air-Water-Ore Simulation) in Ansys CFX’ is closed to new replies.
