November 4, 2023 at 9:39 am
hagos.gebru
SubscriberHello dears, I need to simulate the simple distillation process containing water, ethanol, stillage, and air using fluent. so which approach of multi-phase model should i use for best computational time and accuracy?
regards, -
November 9, 2023 at 12:21 pm
Prashanth
Ansys EmployeeHi,
since it is a mixture, you can think of using a partial pressure driven mass transfer model. Fluent has some options. You can read through this section:Â 14.7.7.2. Equilibrium Models
November 10, 2023 at 7:52 am
hagos.gebru
SubscriberThank you sir, I couldn't get the referance and could you please make it free accessed?Â
January 31, 2024 at 7:28 am
hagos.gebru
SubscriberI couldn't get the referance and could you please make it free accessed?Â
January 31, 2024 at 9:55 am
Forum ModeratorOpen Help in the solver and paste the link into that browser. Or open Help & click on the link if both open in the same browser. The software contains a token/cookie/biscuit to bypass the security stage.Â
February 1, 2024 at 12:13 pm
hagos.gebru
SubscriberThank you got it.
- The topic ‘multi-component multiphase fluid flow simulation’ is closed to new replies.
4602
1510
1386
1209
