March 7, 2019 at 3:30 pm
March 8, 2019 at 11:00 am
Forum ModeratorScroll up and see what triggered it: something has failed in Fluent, and the MPI error is part of the error message.Â
Moving to Fluids too.Â
March 8, 2019 at 11:57 am
snr1
SubscriberDivergence detected in temperature and some mutigrid solver error
March 8, 2019 at 5:56 pm
Forum ModeratorOK, so the solver is struggling with the energy equation, that then diverged and the solution stops. Check the mesh quality and boundary conditions.Â
March 15, 2019 at 10:57 am
snr1
SubscriberI checked boundary conditions and mesh quality. Everything is fine. But still i am getting same error
March 15, 2019 at 11:24 am
Forum ModeratorOK, so there's something else causing the problem. What does the UDF do?Â
March 15, 2019 at 3:06 pm
snr1
SubscriberUDF is for mass tranfer between phases of water and water vapour
March 15, 2019 at 4:28 pm
Forum ModeratorTry running without the UDF and see what happens. If it works you need to review the UDF code and see what's causing the problems.Â
March 15, 2019 at 4:51 pm
Forum Moderatorsnr1Â posted this 15 minutes ago
Dear sir, if I run without UDF, it results floating point exception error and temperature limited in 20 cells of zone1. How to resolve these issues?
Actually, I am simulating the water evaporation process in the helical coil. The boundary conditions are
inlet: water (100%) with mass flow rate inlet and temperature (370K)
wall: constant temperature (500K)
outlet: outflow
operating conditions: 101325 Pa and 300K
saturation temperature in the evaporation and condensation model: 373K with 0.1 frequency.
model: VOF implicit with implicit body force
March 15, 2019 at 4:52 pm
Forum ModeratorFirst off check the model runs OK without any boiling turned on. Then turn on boiling: I suspect you either have too big a time step or the amount of boiling near the wall is giving too great a source term (gas generation) for the solver.Â
March 15, 2019 at 4:56 pm
snr1
SubscriberTime step i have given as 0.0005 and wall temperature is 500k while saturation temperature is 373K
- The topic ‘MPI error’ is closed to new replies.
4818
1587
1386
1242
.jpg?width=690&upscale=false)
