August 28, 2024 at 5:43 pm
August 30, 2024 at 9:21 amAtharv JoshiForum ModeratorHi Guicad,ÂÂLet me check if we can provide sample code in C#.ÂTill then you can refer to the scripting API documentation located at C:\Program Files\ANSYS Inc\v242\scdm\SpaceClaim.Api.V242.ÂAPI document should be able to help you to write the code.ÂÂThanks and RegardsAtharv
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Inventor 2025 files
- SpaceClaim stops sharing topology
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- solidwork parameters for optimization in ansys
624
599
591
366
