May 17, 2021 at 9:32 am
paul.muellner
SubscriberNo movie data generated/saved of FDTD. Log says:
"Adding movie monitor
Could not open video encoder for movie monitor. Cannot continue."
Thank you.
May 20, 2021 at 6:39 pmGeorge Karnos
Ansys EmployeeWhat software and process are you performing when you receive this error?
What version of the software?
Scientific Linux is not a supported platform
May 21, 2021 at 7:48 ampaul.muellner
SubscriberThis issue has been solved already, or at least, there is a work around.
It is a software bug with respect to the frames per second setting.
Values below 25 fps cause this error.
So it has to be ensured (on the cost of performance), that the fps in the movie monitor setting are at least set to 25.
Viewing 2 reply threads- The topic ‘Movie monitor not working in Scientific Linux’ is closed to new replies.
4167
1487
1363
1194
