Materials
Materials
Topics related to Granta Design and more.
Mooney Rivlin Hyper elastomer
    • Harry Begy
      Hello. I cannot fix this issue ! I have changes the substeps, "adjust to touch", Automatic time stepping, rigid body motion etc. Please assist me. Thanks a lot.
      The error is as follows;
      Elastomer Sample (Mooney Rivlin) contains invalid property data. Elasticity is required, but is currently undefined.
    • Mike Rife
      Hi Harry
      That example material only has test data - you still need to add a hyperelastic material model and do the curve fitting.  Mike
    • Rahul Kumbhar
      Hi Harry,
      The error message is indicating missing material property. Can you show screenshot of your material properties?
    • Harry Begy
      Sorry for belated reply. I do the curve fitting and then paste the coefficients. As per attached. it still faces the same error.
    • Mike Rife
      Show the material properties from WB Mechanical.
    • Harry Begy
    • Harry Begy
      So, It does not show the material properities. While, I use the curve fitting and then, the coefficients for Mooney-Rivlin appear in the previous images.
      Thanks for your responses.
    • Mike Rife
      Hi Harry
      On the Workbench project page does the Model cell of the analysis system indicate that it needs to be refreshed?  If so right-click and refresh.  Otherwise lets see what the details of the material model look like in Engineering Data.
    • Harry Begy
    • Harry Begy
      It does not ask for refreshing. Thanks for your help. I am new to this section of Ansys
    • Harry Begy
      Hello. I have checked eveything possible, but unfortunately still face the same error. Any idea?
    • Mike Rife
      Harry
      Are you using a Commercial license?  If so please open a technical support case.  If an academic license (research, teaching etc) ask whomever is in charge of the licenses if they can get this escalated to normal support.  If on a student license - prove that the Mechanical model does not need updating (what does it look like on the WB project page?).
    • Mike Rife
      Harry
      If none of the above, repost this to the Mechanical channel and not the Materials.  Then ask if Peter can look at your model.  He seems to be willing to look at student projects directly (Ansys Employees cannot download files).  See this link; Peter replied:  /forum/forums/topic/creep-analysis-linear-and-quadratic-mesh/
    • Harry Begy
      Thanks for your info. and help
Viewing 13 reply threads
  • The topic ‘Mooney Rivlin Hyper elastomer’ is closed to new replies.
