Photonics
Photonics
Monitor settings for random wavelengths
    • uzmayaqoob1960
      I am interested to simulate my structure for randomly spaced wavelengths.I found that in monitor settings if we go for custom monitor swttings then we can add number of different frequency poibts might be equally spaced and might be not.Figure is attched below
      I have made changes in monitor settings which give us provision to simulate the structure with our custom frequencies .Like as per attachment  i choose custom and add four different frequency points like so.I used few monitors so i made the said selections in each monitor by myself(manually) so that it can record results on our provided four frequency points.But now my question is this in script which is written basically for analysis group where hundreds of monitors can be set just by script command , how can i  write script so that for a large number of monitors existing in a group i can made my required settings as per randomly spaced frequencies without going into manual setting .
    • Amrita Pati
  • The topic ‘Monitor settings for random wavelengths’ is closed to new replies.
