July 5, 2024 at 10:59 am
Vahram Voskerchyan
SubscriberI have setup a MMI simulation following the example on the knowledge base but for some reason my monitor doesn't record the full field profile. Here is the picture of the monitor and simulation setup
The monitor dimenisions are x span = 26e-6 and y span = 11e-6 but the recorded field looks like this:
if I redraw it and expand the axis I will see that nothing is recorded
Thanks! -
July 9, 2024 at 7:15 am
Amrita Pati
Ansys EmployeeHi Vahram,
I apologize for the delay in getting back to you. This is a bit strange. Did you run the simulation directly from the example or are you making any changes to the simulation before running? It looks like the data in the middle portion of the waveguide is missing somehow. Is there any chance you set the span of that cell group to 0 um in the "EME setup" tab of the EME object. In any case, would you be able to share a screenshot of the EME setup tab? Thank you!
Amrita
- The topic ‘Monitor doesn’t record the full data in EME’ is closed to new replies.
4597
1495
1386
1209
