November 21, 2024 at 12:58 pm
Tom Ber
SubscriberHi,Â
I would like to read the reaction moment probe from the contact in a large displacement analysis. When I use the summation method: orientation system or centroid, the moment is read relative to the undisplaced centroid of the contact. I need the summation point to be at the centroid of the displaced contact. Is there any way to do this automatically? The only solution I have found is to move the coordinate system exactly by the value the geometry moves, but this is too labor-intensive to do for many contacts and many timesteps.
When the summation point does not move with the mesh, this results in a false reading of the moments.Â
December 6, 2024 at 2:43 pm
dlooman
Ansys EmployeeDoes specifying a node number on the APDL SPOINT command update the location to compute the moment about?
December 8, 2024 at 10:01 am
Tom Ber
SubscriberHi dlooman,
Thanks for your reply but I don't understand what exactly you mean. Could you please clarify it further?
could you give me some example of apdl code that I could use?
December 9, 2024 at 4:01 pm
dlooman
Ansys EmployeeAssuming you know the x,y,z location of the centroid and have a named selection for the nodes on the surface the commands would be:
cmsel,s,named_selection
spoint,node(x,y,z)Â
fsum
allsel
- The topic ‘Moment Reaction probe with Large deformation’ is closed to new replies.
6790
1332
1152
