July 7, 2021 at 1:29 am
Morice
SubscriberI am attempting to simulate 3-D transient flow over a building in a bid to model velocity, temperature, and relative humidity profiles. Boundary conditions and species properties are set as shown in the screenshots below.
July 7, 2021 at 10:38 amRob
Forum ModeratorThat's the water mass fraction which may be constant if there are no extra sources of moisture. In Fluent look in the Species contours, and if you have an air + water vapour mixture you should see an RH field. Plot that. Remember, in most environmental systems the moisture fraction is constant, but as RH depends on temperature (mainly) and pressure you will see a variation.
July 7, 2021 at 11:49 amMorice
SubscriberThank you, Rob. The relative humidity contours are as expected.
July 7, 2021 at 7:21 pmDrAmine
Ansys EmployeeYeah.
Viewing 3 reply threads- The topic ‘Modelling Relative Humidity’ is closed to new replies.
5879
1306
