December 22, 2021 at 4:31 pm
memo
SubscriberHi Everyone,
I have a pendulum made of a magnet (one end is fixed, and the other has a magnet). I want to model the transient effects of the pendulum's magnetic force on a metallic beam located beneath the pendulum. I thought I could use ANSYS Mechanical for this purpose, but the problem is that I cannot find a way to define this magnetic force in it. I have an analytical relationship that gives the applied force based on the distance from the pendulum. However, I couldn't find a way to link the magnitude of a force in ANSYS Mechanical to the distance of two points (one located on the pendulum and the other one on the beam). I would be very thankful if you could give me an idea to model this problem. Thank you.
December 23, 2021 at 10:42 amSaumadeep Choudhury
You can use the "Magnetostatic" module for this simulation. Please refer - Magnet placement simulation in Ansys Mechanical - Bing video
Also, you can do the same analysis in APDL. Please refer to - 2.8. Magneto-Structural Analysis (ansys.com)
Regards, Saumadeep
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
December 28, 2021 at 2:30 pmmemo
SubscriberHi Saumadeep Thank you very much for your attention. I really appreciate it.
About the magnetostatic solution, do you mean we can simulate transient problems using this solver? Tye pendulum is swinging over the beam.
Viewing 2 reply threads- The topic ‘Modelling magnetic force in ANSYS Mechanical’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- At least one body has been found to have only 1 element in at least 2 directions
- Script Error Code:800a000d
- Element has excessive thickness change, distortion, is turning inside out
- Help to do quasistatic analysis in static structural module
- Image to file in Mechanical is bugged and does not show text
Top Contributors-
1987
896
599
591
408
