January 22, 2019 at 5:04 pm
kawad24
SubscriberDoes anyone know of a way to model roughness through the walls of a channel for both laminar and turbulent flow in ansys fluent?Â
January 22, 2019 at 5:49 pm
DrAmine
Ansys EmployeeThis is pure research but generally laminar flows are not influenced by roughness as the streamlines will cover the roughness being stratified. Consequence is the friction factor is independent of roughness. For turbulent flows sticks to omega based models in Fluent and use standard wall resolution as if the wall is smooth. -
January 24, 2019 at 6:23 am
DrAmine
Ansys EmployeeSans grain height or something equivalent is tout roughness height. -
January 24, 2019 at 7:18 pm
Raef.Kobeissi
SubscriberNot sure if it is suitable:
https://www.youtube.com/watch?v=DN5QMCuJUb8
January 28, 2019 at 5:07 am
kawad24
SubscriberIs this method equitable to roughness heights by using an Ra value?
January 28, 2019 at 6:19 am
DrAmine
Ansys EmployeeCheck paper of Adams for that to relate measured values to sand grain roughness. "A simple algorithm to relate measured
surface roughness to equivalent sand-grain roughness" -
January 29, 2019 at 6:18 am
DrAmine
Ansys EmployeeIt should increase -
February 4, 2019 at 7:21 am
DrAmine
Ansys EmployeeAs ANSYS-Stuff we can only comment on attached pictures.Â
February 4, 2019 at 4:30 pm
DrAmine
Ansys EmployeeAnd what is now going wrong? Provide more information about boundary, conditions and your judgment of the result.
February 5, 2019 at 2:57 am
kawad24
SubscriberThe problem I am facing, is that when I add a roughness factor on the walls, the pressure differential is decreasing rather than increase. The center of the model is an air fluid region with a mass flow rate inlet and pressure outlet. The fluid is surrounded by aluminum walls with a constant heat flux on the top wall and insulated on the left and right wall as well as the bottom. I am not sure why this is the case? I was questioning my mesh being too course and possibly giving invalid results. Or a possible error in the settings:
·      Turbulent: Viscous-Standard K-Epsilon approximation.Â
·      To model forced convection, the density was set to as a model approximation to assume incompressible ideal-gas
·      Operating pressure: 98,338.2 Pascal (14.2 PSI)
·      Gauge Pressure at outlet: -1112.3 Pascal (-.16 PSI)
February 5, 2019 at 8:03 am
DrAmine
Ansys EmployeeWhich near wall method are you using? Do you exp. data or any correlations?
February 5, 2019 at 9:02 pm
kawad24
SubscriberI was using the scalable near wall function.  I am trying to simulate this and will be experimentally be verifying the results. I just don't understand why the wall height i place isn't following the predicted trend for pressure differentials
February 6, 2019 at 4:43 am
kawad24
Subscribercan you tell me what settings were used for this turbulent model? For some reason, my pressure differential is decreasing as the roughness is increasing. I see the K-Epsilon model, realizable model was used, but is there something else I should be aware of?
February 6, 2019 at 6:04 am
DrAmine
Ansys EmployeeI do not understand your density setting. Regarding viscous model and near wall modelling I recommend using sst model. -
March 6, 2019 at 8:43 am
DrAmine
Ansys Employee1/It is up to you to choose the most suitable meshing method. Just fulfill the mesh metric quality requirements: Aspect Ration, Cell Volume Change, Skewness and Ortho Quality.
2/Create an iso-surface based on Mesh>X-Coordinate
June 1, 2020 at 10:26 am
regitasyali
SubscriberHi, can you provide reference for this statement please? Thanks.
- The topic ‘Modeling Roughness on a channel’ is closed to new replies.
5849
