April 19, 2024 at 6:28 am
Wu PeiNan
Subscriber -
April 19, 2024 at 12:23 pm
Forum ModeratorYes, that will work.Â
April 19, 2024 at 2:17 pm
Wu PeiNan
SubscriberThanks for you replied, Rob.
When I choose a semi-closed pipe to simulate a methane explosion, I always fail to ignite in this model, why is that?Â
I used the simple pipe model, and I think if that there are any requirements for the mesh? Or which setting I ignore?
I would appreciate it.
April 19, 2024 at 3:08 pm
Ren
Ansys EmployeeCould you provide more details of what you are doing, for example,
geometry dimensions
combustion model
initial conditions
chemical mechanism
solver settings
April 19, 2024 at 4:24 pm
Wu PeiNan
The model is a rectangle pipe with length of 5 meters and width of 0.3 meters. The combustion model is the finite rate/eddy dissipation model, and its initial condition is shown as following figure, with the CH4 combustion reaction.
For the solver, I choose pressure solver and simple algorithm with step of 0.005 seconds. -
April 22, 2024 at 2:39 pm
Ren
Ansys EmployeeSo what is your actual question?
April 22, 2024 at 3:55 pm
Wu PeiNan
I can't light this model a lot of time, and even if I do, there will be irrational situations like this. I don't understand what is wrong with this. Is it the grid or a certain setting? Like this one, it lit up but the flame spread along the wall.Thanks for your response, this question has been bothering
 me for a long time.
April 22, 2024 at 3:57 pm
Wu PeiNan
SubscriberOr do I need any additional setttings for ignition via patch to ensure that my model can simulate CH4 ignition and explosion?
April 23, 2024 at 2:16 pm
Ren
Ansys EmployeeHello,
- Is the pipe open-ended on both sides, or closed at one end and which end?
- If detonation is expected, I suggest you use the density-based solver (DBNS). The pressure-based solver (PBNS) should also work if the Mach numebr does not go very high.
- I suggest you use the "Finite-Rate/No TCI" option.
- Are you using a 1-step reaction scheme or multiple reaction scheme. For 1-step reaction, you need to patch a temperature and the composition that correspond to the burnt state of the mixture.
- The mesh needs to be sufficient fine around the flame front (and also shock wave). You can use automatic mesh refinement/coarsening
- The time step size also needs to be much smaller because everything goes very fast. I think 0.005 s is too large. It needs to be around 1E-5 s, or even smaller.
- The topic ‘Modeling Methane Explosion Ignition by Patch’ is closed to new replies.
5769
