Systems
Systems
Topics related to Twin Builder, medini analyze, VRXPERIENCE and more.
Modelcenter MBSE via Cameo: passing part properties
    • max.harrow
      Has anyone used Modelcenter MBSE via cameo to send a part property as an object (rather than a value property with a primitive number/string/boolean) into a modelcenter workflow? And if so, how have you been able to access the information inside that part property (sub-parts, values, etc) within the modelcenter workflow? I know how to send the value properties to modelcenter and offload the calculations, but cameo simulation toolkit is still orchestrating the calculations and its performance is very slow. I want to offload the orchestration as well as calculation, by just sending the objects to modelcenter and going through it in a tool with better performance.
    • Ajay Agrawal
      Hi Max,
      Unfortunately ModelCenter don't have support for Data objects today, but we have considered this use-case and requirement for our product backlog. We will keep you posted on the progress of this request.
      Ajay Agrawal (Product Manager, Ansys ModelCenter)
