Electronics
Electronics
model file
    • Davidrobot
      I am doing example following 2D tutorial. Anyone can let me know where I can get the file: Ex_7_02_Solenoid.sm2, or dimensions of components?
      Thanks!
    • Navya Chode
      Can you provide the below information?
      1)Which version of the tutorial file are you using? usually, if they are from Ansys learnig hub you will get the simulation files along with the tutorial package.
      2)I am assuming you are talking about Ansys Maxwell example. which version of AEDT are you using?
      you should be able to find some solenoid examples inbuilt in AEDT. Go to FILE>Open Examples>Maxwell
      Regards Navya
  • The topic ‘model file’ is closed to new replies.
