Photonics
Photonics
MODE: Thermooptical Simulation gives “wrong” results
    • Leon Neymeyer
      I am importing temperature data from Lumerical HEAT to simulate a thermo-optical effect. I used your instructions to do this. The only difference is that I don't sweep over the power, but give the electrode a temperature as a boundary condition. I also sweep over this which works fine. Now I import the data and save the effective refractive index.
      I calculate the phase shift as follows
      phase = 2*pi*(neff-neff0)*L/lambda;
      The first temperature value from the thermal simulation is 293.15K, i.e. room temperature. I would expect neff and neff0 to be equal and the phase shift to be 0. Instead I get a value not equal to 0. I have now changed the "reference temperature" in the material database which did not fixed the problem.
      I would expect 0 phaseshift at the first value:
      Here is my code:
      # Temperaturdaten importieren ########################
      temp = linspace(293.15,473.15,7);
      neff = matrix(length(temp));
      addgridattribute("temperature");
      matlabload("T_temp_sweep.mat");
      select('temperature');
      importdataset(T);
      # Brechungsindizes berechnen
      switchtolayout;
      setnamed('temperature','enabled',0);
      setanalysis('wavelength',1.56e-6);
      findmodes;
      neff0 = real(getdata('mode1','neff'));
      for (i=1:length(temp)){
      switchtolayout;
      setnamed('temperature','enabled',1);
      setnamed('temperature','Temperatur_index',i);
      findmodes;
      neff(i) = real(getdata('mode1','neff'));
      L_long = 6760e-6;
      L_short = 4327e-6;
      L_avg = 5543e-6;
      lambda = 1.56e-6;
      phase_long = 2*pi*(neff-neff0)*L_long/lambda;
      phase_short = 2*pi*(neff-neff0)*L_short/lambda;
      phase_avg = 2*pi*(neff-neff0)*L_avg/lambda;
      Thanks in advance!
      Leon
    • Leon Neymeyer
      Pretty simple solution. I just had to set the simulation temperature in FDE.
    • Ashish Khemka
      Thanks for sharing the answer.
  • The topic ‘MODE: Thermooptical Simulation gives “wrong” results’ is closed to new replies.
