August 22, 2024 at 7:11 pm
l.v.lozovski
SubscriberI have this simple structure, with the waveguide in red and the electrode in yellow, in MODE FDE with metal boundary conditions. I want to check the loss due to metal. I noticed that when I modify the size of the mesh override region (only a little bit so that the waveguide still stays inside and the simulation region stays enough far) the calculated modes change a lot...why?? I would like to have some personal support because it seems like very specific problem
August 23, 2024 at 5:38 pm
Guilin Sun
Ansys EmployeeThis is because by default the mode finding begins from the largest neff, which is mostly inside metal.
You can uncheck "use max index", and specify the original neff data in "n" from the case without the metal.
you may also need to set more number of trial modes, since even though you set the "n" at the neff from previous result, it may begin from larger value.
5899
1306
