TAGGED: #Modal_Analysis, apdl, file-txt, stiffness-matrix, student-version
November 3, 2024 at 3:53 am
blmcdona
SubscriberHello,
I am analyzing a steel pipeline in Ansys modal, using a student version license. At the end of the analysis, I have APDL commands to write the stiffness matrix as a .txt file. Unfortunately, though, the stiffness matrix is not being written when I run the analysis. Does Ansys Student support stiffness matrices?
Thank you and best wishes,
Brandon
November 3, 2024 at 2:08 pm
November 3, 2024 at 9:01 pm
blmcdona
SubscriberI wrote the following code in the APDL commands:
Â! Define the output file name*SET, FileName, 'C:\Users\brand\Documents\CIE 516\Term Project\stiffness_matrix.txt'Â! Export the global stiffness matrixematwrite, FileNameÂHowever, the .emat file is not being created. Is this feature supported in the student version? -
November 4, 2024 at 10:53 am
Stella Peloni
Ansys EmployeeHello Brandon,
Please set the Delete Unneeded Files to No, and The Future Analysis to MSUP Analysis in the Analysis Data Mangement. Then, under the Modal Analysis, insert a command object and write : EMATWRITE, YES.Â
Kind Regards,
Stella
November 4, 2024 at 4:54 pm
blmcdona
SubscriberThank you for your reply. I made the recommended changes, but the stiffness matrix is still not being written. This is the code I used:
Âematwrite, 'stiffness_matrix.txt' , 'yes'ÂWhere the command is located in the "Modal" part of the project tree, rather than in the "solution" branch. Is the command correct, or is the placement of this command object wrong?
November 4, 2024 at 6:05 pm
November 4, 2024 at 7:31 pm
blmcdona
SubscriberI have done that, but it is not being exported. How do I make Ansys write the stiffness to a .txt file?
November 4, 2024 at 7:56 pm
blmcdona
SubscriberI am using the Student Version of Ansys. Is the "ematwrite,yes" command supported with this software version?
5899
1306
