TAGGED: ansys-fluent, meshing, multiphase, spaceclaim, workbench
September 19, 2020 at 2:18 am
johan_betancour
SubscriberHello everyone,
I have ANSYS 2019 R2 and I'm having problems using fluent with meshing mode and the watertight workflow, I need to report the torque generated on a rotor, for which I have created in spaceclaim a named selection with all its walls. as you can see:
September 21, 2020 at 9:42 amKeyur Kanade
Ansys EmployeePlease use latest version 2020R2 or 2020R1. nWhat is domain and domain-shadow? nIt looks like you have blade completely inside. Please use appropriate options while describing geometry. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnnViewing 1 reply thread- The topic ‘Missing surface from fluent meshing to solver’ is closed to new replies.
Innovation SpaceTrending discussions- JACOBI Convergence Issue in ANSYS AQWA
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
Top Contributors-
4597
1495
1386
1209
