March 26, 2024 at 6:47 am
alisa
SubscriberHi,
I want to know how to set the MFD of the light source (is it the port geometry?) and the size of the mode fields (results in each EMECells) in spot size converter simulation using EME as in the example SSC simulation
Thank you so much
March 26, 2024 at 7:57 pm
Amrita Pati
Ansys EmployeeHi Alisa,
Are you looking for the horizontal/vertical MFD (1/e^2 or 1/2) for the input mode?
Amrita -
March 27, 2024 at 12:27 am
- The topic ‘MFD in spot size converter’ is closed to new replies.
1587
1386
1242
