April 13, 2025 at 10:04 pm
diop.mohamed2
SubscriberHi.
I would like to simulate methane combustion in a ramp burner but I've some difficulties to correctly define the combustion domain.
It would be a pleasure to receive your suggestions.
The error message indicates that the outlet is adjacent to a solid domain.
Kind regards -
April 14, 2025 at 8:52 am
Forum ModeratorAssuming you're using Fluent, check the cell zone assignments relative to the flow boundaries. You're not allowed to have flow boundaries adjacent to the solid zones. Note, in Fluent we have fluid & solid zones: in CAD they're all solid.....Â
April 14, 2025 at 9:37 am
diop.mohamed2
SubscriberThanks Dear @Rob for your reply. I'm using Fluent.
The system I'm studying consists of two parts: the ramp burner itself and the combustion chamber.
The ramp is made up of air and fuel inlets and mixture injection orifices (nozzles) all along the surface of the tube.The difficulty I'm having is defining the combustion chamber so that combustion takes place within it and not in the burner (between the inlets and the nozzles).I used the enclosure option but it didn't work. With the extrusion method, I end up with the above error . -
April 14, 2025 at 10:20 am
Forum ModeratorIf the air-fuel mixture wants to burn in the wrong place that tends to mean there's a problem with the model.Â
The above suggests you're not modelling the domain well. Have a very careful look at the geometry and work from there. Enclosure was designed for aircraft etc, for burners I'd always build the geometry for the injectors & flame zone in the "normal" way.Â
April 14, 2025 at 10:47 am
diop.mohamed2
SubscriberOkay. Thank you very much.
April 14, 2025 at 3:54 pm
diop.mohamed2
Subscribercould I have an illustration or tutorials in this area please?
April 14, 2025 at 4:06 pm
Forum ModeratorIt'll be covered in the geometry training, check in Learning and also the tutorials in the Help system  https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/main_page.html?hl=f
April 14, 2025 at 4:45 pm
diop.mohamed2
SubscriberAll right.
Thanks
4607
1515
1386
1209
