May 17, 2024 at 12:17 am
yusuke_1.ban
SubscriberHi!
I would like to create a phase map  into an H5 file, and make it function with the lumerical-metalens-XXXX.dll for metalens data.
I generated myself without using lumerical solver or get_YY_phase inÂ
Generate_phase_map.lsf
https://optics.ansys.com/hc/en-us/articles/18254409091987-Large-Scale-Metalens-Ray-PropagationHow can I generate the H5 myself?
What are the minimum necessary values required?
Is there another way to load the phase map (preferably just the phase) into OpticStudio?Thank you in advance.
May 17, 2024 at 6:42 pm
Guilin Sun
Ansys EmployeeYou can generate your own phase with 3rd party tool. But it is strongly recommended that you import your data into Lumerical and save it.
h5 data has library and data format requirements
https://optics.ansys.com/hc/en-us/articles/360034927413-h5info-Script-command
Please use Lumerical script to write it:
Please follow the metalens examples.Â
Of cource you may develop your own way to drive the data from Lumerical to OPticsStudio. Then you will need time and efforts to do it if it is different from what the examples provide.
- The topic ‘metalens data h5 file using self-generated phase’ is closed to new replies.
5849
