Meshing Problem
    • Muhammad Orabi
      Hello, I am trying to simulate a wind turbine on Fluent with a rotating domain that contains the subtracted shape of the turbine and a static domain that contains the rotating one.
      However, there seems to be a problem with the meshing. I made sure that the geometry is clean using SpaceClaim, and I tried different sizes for the mesh. I also tried different methods (patch conforming tetrahedrons, multizones, and sweep), but the issue still persists. I always get the error "One or more entities failed to mesh. The mesh of the bodies containing these entities may not be up-to-date." I believe the issue is in the rotating domain only because it is the one showing a failed mesh (yellow region).
      Any advice would be appreciated.
    • Keyur Kanade
      The blade surfaces are very curved. Split that single blade surface into 5 to 8 surfaces. Also make sure you have using correct sizing.
      PLEASE GO THROUGH HELP MANUAL FOR MORE DETAILS
      REGARDS,
      KEYUR
      HOW TO ACCESS ANSYS ONLINE HELP DOCUMENT
      GUIDELINES ON THE STUDENT COMMUNITY
      FLUIDS ENGINEERING COURSES | ANSYS INNOVATION COURSES
  • The topic ‘Meshing Problem’ is closed to new replies.
