April 15, 2021 at 10:02 pm
talimu
SubscriberHi Lumerical Support team,
In your FEEM Solver Course, you refer to one example file called: soi_wg.idev.
In this example, there 3 kinds of meshing on the Silicon waveguide:
1) Mesh inside material definition of waveguide structure:
April 16, 2021 at 6:46 pmTaylor Robertson
Ansys EmployeeHello Tali,nTo better understand the mesh order, and mesh settings I would recommend the following pagesnIn short:n1) Mesh priority: determines what material/interfaces are used in the meshing process. This determines how the simulation is partitioned, but not actual the settings of the mesh.n2) These are global properties of the mesh, during the FEM meshing process the grid will be refined everywhere until it meets these criteria.n3) The mesh constraint allows you to change the local mesh properties. These can be used to further refine the grid in specified regions, such as near metallic interfaces where the fields will be tightly bound. If the mesh constraints are larger then the global properties 2) then those will used instead.nnI hope this helps.nI would study the first link, and play around with partition and mesh command to see how these features work. You can do this by inspecting the grid.nBest,nApril 17, 2021 at 10:06 amtalimu
SubscriberHitroberts,nThank you for your reply. It was really helpful.nRegarding reply 3) above:nHow should I refer to the global mesh constraint here in the current example? If edges per wavelength is 2 and my wavelength is 1.55 micron, so is it quantitatively higher or lower than added mesh constraint saying max edge length is 0.01micron? nThanks, nTali M.April 20, 2021 at 4:34 pmTaylor Robertson
Ansys EmployeeThe wavelength is the wavelength in the material. This is the free space wavelength divided by n. nlambda = lambda_0/nnUnless n is greater than 155 , max edge length should set mesh sizennApril 20, 2021 at 7:52 pmtalimu
SubscriberGreat, Thanks trobertsnViewing 4 reply threads- The topic ‘Meshing Priority’ is closed to new replies.
6485
