October 30, 2024 at 1:46 pm
per.pucher
SubscriberHello everyone!
I'm currently trying to mesh thin wires (0.05mm x 0.05mm x 50mm) within a larger structure. See picture below. I tried to make a midsurface out of the wires in Spaceclaim but I get an error message (impossible to create midsurface, the faces could not be shifted). Is there another way to mesh these thin wires, like modeling them as 1D beams ?
Thanks, kind regards.
October 30, 2024 at 2:21 pm
Deepak
Ansys EmployeeHi,
Please try Extract option, to generate 1D Beam element.
Deepak K.
October 30, 2024 at 2:23 pm
ErKo
Ansys EmployeeÂ
Hi
Shell:
Because they are so thin, one can just select on of these faces (belonging to the thin parts shown), and do ctrl+c, and ctrl+v which will give us a new surface body that can be meshed with shell elements later (and connected to main body using contacts).
For beams see the above post.
All the best
Erik
October 30, 2024 at 2:41 pm
per.pucher
SubscriberThank you very much, your responses solved my issue !
Per P.
October 30, 2024 at 5:48 pm
ErKo
Ansys EmployeeGreat that it helped
All the best
Erik
- The topic ‘Meshing of thin rectangular wires’ is closed to new replies.
5934
1306
