May 22, 2024 at 11:36 am
mauryaabha1602
Subscriberhow to provide meshing in nanoparticles? and what caution I should keep in mind for nanoparticle meshing??
May 22, 2024 at 11:32 pm
Kyle
Ansys EmployeeHello, which software are you using? Assuming you mean Lumerical FDTD, you should make sure that there are at least a few mesh cells over each nanoparticle. A finer mesh will be more accurate, but the simulation will take longer. You can refine the mesh over the nanoparticles specifically using a mesh override object. Convergence testing should be used to determine how fine a mesh you need.
- The topic ‘meshing of nanoparticle’ is closed to new replies.
