Preprocessing
Preprocessing
meshing of a hemisphere
    • rupali.pandey
      hey, Can anyone suggest how to mesh the geometry (attached below).
      Thanks in advance.
      In SpaceClaim, use 2 orthogonal planes to split the body into 4 pieces then on the Workbench tab, use the Share button to have the mesher connect the elements across the cut surfaces.
    • rupali.pandey
      I have cut the hemisphere using orthogonal planes but then also I am not getting appropriate mesh (meshing through thickness) when meshing in Ansys mechanical. Please suggest some appropriate method.
      Please show the mesh you got on one quarter piece and sketch what mesh you wanted.
      On the original goemetry, there is a concave face and a convex face. You could pick one of those faces to be the source face to build Inflation layers in the quarter piece.  Having inflation layers on both faces is problematic because those two faces meet at a common edge.
    • rupali.pandey
      I have sliced the hemisphere into multiple parts (figure enclosed).
      Also, I carried out meshing which seems to be poor. I used many mesh techniques to mesh the same. But I am still facing issue to mesh the hemisphere through thickness in ansys mechanical.
    • Govindan Nagappan
      Turn off thickness display. Go to Display tab and click on thick shells/beams
      Is the original geometry just 2 surfaces and not a solid body?
    • rupali.pandey
      The original geometry do consist of solid body.
Viewing 7 reply threads
  • The topic ‘meshing of a hemisphere’ is closed to new replies.
