August 28, 2024 at 1:44 pm
Hitarth Trivedi
SubscriberHI, I have an issue related to meshing in Ansys workbench.
Even Though, I selected line bodies in geometry properties I am not able to mesh line bodies. It is giving the same results as the images below.Â
Please, let me know the solution as soon as possible. I have already applied the cross -section.
August 29, 2024 at 1:22 pm
Aniket Chavan
Forum Moderatorthe body is meshed. which is evident from 3 things:
green crossed check in front of the the body, mesh is green check, and you will see some nodes and elements in statistics.
-Aniket
1885
1404
1303
