August 16, 2018 at 8:02 am
fulcrum
SubscriberHello, I'm new to Ansys.
I need to model heat transfer in a pipe-in-pipe HE.
Inner tube has many thin extruded fins: 250 in total. Tube length 100 mm.
Now my question(s):
1) Is this problem solvable on a ordinary PC ? 6 GB of RAM, 2.3 GHz.
2) Any meshing methods advice before to start ?
Please see the attached pictures:
Heat ExchangerÂ
Inner_TubeÂ
Inner_Tube_2
August 16, 2018 at 3:50 pm
Forum ModeratorWhat do you actually want to model? Ie fluid heat transfer to the solid, stresses in the solid etc.  From there the community can probably guide you.Â
August 16, 2018 at 6:39 pm
fulcrum
SubscriberGiven the inlet pressures and temperatures of the two fluids I need to model heat transfer through the finned pipe wall, outlet temperatures and hydraulic losses.
Hot fluid (gas, combustion products) flows in the inner tube. Thanks. -
August 17, 2018 at 1:05 pm
Forum ModeratorOK. Given the mesh limits on the Student & Teaching software I'd look at a 2d-axisymmetric model in Fluent. You then model a slice of the geometry, and can mesh the fins with enough resolution to get that information.Â
There are some geometry & mesh requirements so have a look at the documentation before starting to work with the software.Â
- The topic ‘Meshing: Finned Tube Heat Exchanger.’ is closed to new replies.
5834
