November 24, 2019 at 9:18 pm
usamaubk
SubscriberThe global min size has been replaced by the mesh size of a premeshed edge or face which is smaller. Please check the premeshed edge or face.
A software execution error occurred inside the mesher. The process suffered an unhandled exception or ran out of usable memory.
Could anyone figure out whats the problem in the mesh.. I guess its in Mutlizone meshing regions but i cant seem to overcome it. I will be thankful if someone can sort it out
https://drive.google.com/open?id=1exRqH2mkCLEch51iSEZLUz6DSMoOHzEE
November 25, 2019 at 2:26 am
peteroznewman
Subscriber -
November 25, 2019 at 11:38 am
Forum ModeratorPeter, I think you put your finger on the problem. I could add that you'd nailed it....  Depending on resolution you'll need a fair bit of mesh.Â
usamaubk - which licence are you using for this?Â
- The topic ‘Meshing Error’ is closed to new replies.
3892
1414
1241
1118
1015
