May 28, 2020 at 1:37 pm
PippoLomi
SubscriberGood morning,
for my final degree i need to perform a cfd analysis of a centrifugal compressor. For meshing process I use TurboGrid. For have a complete control over the boundary layer, I want to calculate the correct number of cells inside it. From User's Guide, it is possible calculate the number of cells present in boundary layer with a very simple formula:
Base Count * Global SIze Factor * (Factor Base + Factor Ratio*Global Size Factor).
I have already understood all the parameters except for Base count.
I tried to find it inside TurboGrid panels but I failed.
Could anyone explain the meaning of "BASE COUNT" words?
Where can i find that value?
How can i calculate Base Count Parameter?
Thanks in advance
- The topic ‘Meshing Centrifugal Compressor’ is closed to new replies.
6570
1311
