August 21, 2026 at 2:00 pm
kumar-a16
SubscriberHi everyone,
I am setting up an ICFD simulation of gas flow through a porous domain in LS-DYNA. The model currently consists of the fluid domain and the porous-medium region; I am not yet including structural deformation.
During initialization, the simulation terminates with the following error:
Â*** Error 120003 (ICFD+3)ICFD::ERROR: Invalid BC on SIZE or INTERF surf. PID 1ÂÂThe simulation does not proceed beyond initialization.
I am using an ICFD volume part for the porous medium and have defined the corresponding ICFD material and porous-medium model. I suspect that the issue is related to the boundary condition assigned to the surface with PID 1, but I am unsure what constitutes an invalid BC for a
SIZEorINTERFsurface in this setup.Could someone please clarify:
- What does "Invalid BC on SIZE or INTERF surf. PID 1" specifically mean?
- What boundary conditions are permitted on
SIZEandINTERFsurfaces? - How should the surfaces of a porous ICFD volume be defined when modelling hydrogen flow into/through porous soil?
- Is there a particular ICFD keyword or surface definition that I should check?
Thank you in advance.
